turbo leak
turbo leak
i was wondering if any body would have an idea of what could be happening, car runs normal, turbo boost just fine, but for a few days smoke started to pour out the exhaust system. I justed for leaks where i thought it could be at, then i ended up removing the down pipe and the back side of the turbo is filled with oil. Do any body have an idea if the turbo has a oil seal somewhere? thanks for the help, MIC.
Yes there are seals in the turbo and yours are shot. At the very minimum you need a rebuild. You should stop driving it in this condition. The oil can foul out your O2 sensor, I'm speaking from experience. Also, with it burning oil like that you can potenitally run low on oil and possibly cause engine/turbo damage. Is there a lot of shaft play?
nope, no shaft play, not much anyways. Do you think if the returned line was resticted would cause the oil to come out the back side? How much would a rebuild would cost anyways?
Yes a restricted drain line definately can cause oil to build up in the turbo. However if you are single which it sounds, and you used the stand earls line straight down you should have no issues. Unless of course you boost the almight hell out of it and then turn the car off real fast. That will coke up the oil in the drain and cause a puddle. Easy enough to check.
A turbo rebuild can be a range of prices depending on who does it. Expect a few hunderd dollars to go through it replace seals, rebalance and reassemble. I think it's a good excuse to upgrade that snail.
What size line do you have for a feed and is your turbo ball bearing?
the size of the turbo is a to4e turbo from turbonetics, i'm thinkin it's bb, i'm only running 10 psi, but for some reason when i have to stop really fast, the car does stall on here and there, maybe thats theproblem with the hot side of the turbo? i don't think it's a blown turbo, leaking maybe, like i said it still runs normal and boost just like it normally does and the oil level has been the same, hasn't gotten low or anything, not much shaft play at all? I did find another problem, my return line did have a tear in it and oil did get to my wastgate dump pipe thats connected to my down pipe, maybe thats one reason why oil is getting to the exhaust and the line is something like -4 for the return.
Think about how hot your exhaust side gets. If you see any puddling in there at all, that is the oil that didn't get burned off. Any oil that makes a visable puddle on either side of the turbo is a BAD thing.
I've heard that if you are using a bb turbo and your feed line is larger than a -3 than that could be the issue as well.
so, yeah, you guys are right, i'm thinking the turbo is blown now, it starting to make funny noises and oil is coming out the compressor side now, another thing since it's a t04e-60 turbo, that makes my flange a t4, right? What do you guys think, rebulit or buy a new turbo?
Sunroof Surfer
thats a t4 flange! and why is it blown... its not BALL BEARING if thats what ( bb ) stands for ur turbo cant be blown u dont even boost the crap out of it ... worste case its a bad oil seal........ if the fins are wet on the exhaust housing side then its a bad seal... u gotta take it apart!........ its not blown if ur boosting
post pix up Mike!
post pix up Mike!
post pix up Mike!
post pix up Mike!
Sunroof Surfer
your right too kaiser but unless he smoking like crazy out the exhaust then... yes its blown, but he's not and oil is all over on the back housing then its def. the turbo seal....and as u said kaiser... MIKE STOPPPP DRIVING THAT CAR!! and take apart the turbo! get it rebuilt turbonetic's sell's turbo rebuild kits too or just send it to them to get rebuilt!!
It is easily blown, I have blown my turbonetics turbo twice in six months. It doesnt matter if it doesnt have BB. the seals around the shaft start to leak and that is considered blown.
FYI there is a company named majestic that can rebuild turbos, if turbonetics doesnt want to or cant do it.
