what do u guys think of a gs300 stock block with a 2jzgte head
i have a stock gs im thinking of puting a 2jzgte head butt i dont know what probs i will run into yet what do u guys think.....???
can be done, but you lose the oil squirters that you get in the GTE block - I've heard of people drilling the squirters in the GE block. Are you planning to change the crank/rods/pistons as well? As the GE runs much higher compression than the gte - they don't take kindly to running the same levels of boost that the GTE can.
Maybe just do an NA-T?
why not just turbo the motor? the way i was thinking is that if you going to use the stock twins, it wouldn't be as fast or fun then turboing it, plus less hassle. for the ge motors, i seen a few stock ge blocks hitting 8 and 9 at the track, but i do live by dave henry, sure the ge motors aren't as strong as the gte, but it's not that much a fall off.
The old saying holds true "do it once, do it right"
Or you could just move to Australia and get a JDM Aristo
There are some other cost associated with this swap. You'll obviously need the intake and exhaust manifolds. You'll need to run a different ignition setup or whole ecu since the GE uses a distributor and the GTE runs on coilpacks. Not out of necessity but you would have distributor and turbo clearance problems unless you ditch the stock twins.
suprakidxx
Performance & Maintenance
17
06-01-15 06:41 PM
JDMSoarer5
08-23-12 09:30 AM
