problem with my car
did you fill it up correctly? you may have air in the system which will cause you problems.
you should do it with the engine running (when its cool, obviously). give it some revs to get the coolant circulating in the system and add some more.
Water pump leak?
I was loosing coolant also, very slowly.
It turned out that there was a crack/leak on the water pump. Replaced the water pump.
Do a visual check from the passanger side - you should be able to see the water pump. Check it while the engine is running. My car dripped a dropplet of coolant.
