How do you remove front Seats?
I have a 95 Gs300 with leather seats, however the motors seemed to either be broken or the track is dirty, I cant seem to move the seat forward or backwards. All the other functions work fine so I know it has power going to it.
I want to remove the front seats but dont know where to begin, any suggestions?
Thanks
Thanks
Thanks
Thanks
If your only going to fix the seat motor, you only need to loosen the 4 bolts that are holding it down.Once you remove the bolts just tilt the seat back and you can access the bottom were all the mechanicals are..Now , if you need to remove the seat after you remove the 4 bolts you need to loosen the seatbelt assembly because its attached to the seat.Word of advice, be careful when you are pulling your seat out because you dont want to hit your door panel..Hope this helps...
Purplexed
SC- 1st Gen (1992-2000)
10-26-01 10:45 AM
