Removing Rear seat
Removing Rear seat
Just to clean and for general purpose, How do you remove the rear seat on Our model car? I looked for bolts, tacs ect and could not find anything.
Thanks,
SISMO817
Thanks,
SISMO817
Remove the head rest?
Never had to do that on mine.
SISMO, just pull up the bottom seat, then you will see 4 bolts..2 under the carpet on the door-sill, and 2 in the middle next to the belt buckles.
Just pull up the bottom, take it out. Loose the 4 bolts at the bottom. After the bolts are loose, lift the seat str8 up then pull out. Easy shouldn't take long.
