Haze on Instrument cluster
I have this weird Haze on my instrument cluster, when I first got the car I figured it might be moister or a thin film of grime. I took the dashboard appart and took the cluster, removed the clear plastic and cleaned the HELL out of it with 1. windex 2. Plastic cleaner 3. Shaving cream (yeah it sounds weird but it actually did remove some of it)
After an hour of elbow grease, nothing. Any TIPS?
I would certainly not use the same technique that I used for the headlights.
I used Plastix too on haze/smudges on my instrument cluster that would not come off using anything else and it got most of it off. It is kind of tough to work it in because of the steering wheel so you may want to use a q tip to get at the corners.
Well for the Head lights I have tried "brake fluid". Now I HAVE NOT TRIED THIS ON MY LEXUS. However I did do it on my wifes Neon and it works pretty well, gets rid of the haze and yellow film. But yeah just take some brake fluid and a rag and go to town. Make sure you clean off the fluid clean but it does a good job.
spinedoc
10-18-01 08:08 AM
