fastest/quickest 1st Gen GS300
Rob, if your talking to me. Im NA still but am building a jdm GTE in the garage.
weisco
eagle
pt67
custom rail with 780's
emanage blue (maybe ultimate before it goes in ?)
fleebay cooler
tial 50mm bov
Tial 44mm wg
dual walbros
weisco
eagle
pt67
fleebay cooler
tial 50mm bov
Tial 44mm wg
dual walbros
hmm, ok. Just wondering because I think the 850's I just purchased are the same kind and they won't fit the N/A rail. I may just weld up around the injector holes and drill larger. I don't know of an aftermarket rail that will fit the N/A runners.
Also, I just purchased a GT42. I am looking to push 800-850rwhp.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I just can't decide whether I go toyota BL tranny or TH400.
For that kind of power I gaurantee your gonna need the th400. Which BTW ross also carries some cool parts for.
Everyone I have talked to about any of the built toyota trannys says the same thing. They may work for a while, but you are gauranteed it will break. Just a question of when.
Im either going to do a TKO600 manual or a 4L80e auto. Havent decided yet.
But my car is a daily and weekend driver so the 400 wont cut it for me.
4L80e? I hear you had to do a lot of tunnel mods to get these to fit, and there are only a few places that can build them to handle the power. The 4L80e is just a newer version of the 700r4 right?
How much your fuel rail costing you?
I spoke to a few companies that can build them for around 400bux more than a th400. And the 4L is a th400 with OD. There is also the 4L60 and 700r4 though I hear those arent as strong.
Since I have the taps and AN fittings already, the rail is going to cost under around 50-60bux
^Additional info from above thread ^
I found the link for the rail build. Its a gte but it should be similar.
I ordered my rail stock last night. Ill post an build up.
Peep these http://www.supraforums.com/forum/sho...king+fuel+rail
http://www.supraforums.com/forum/sho...d.php?t=408750
Does anyone with the 1st Gen GS300 ever do a 1JZ swap instead of doing NA-T or GTE swap?
Reason i'm asking is because i've been thinking about picking up a 1st Gen GS and doing the 1JZ to use for a DD. I should probably do more reasearch on this too.
You should talk to El Captain. I believe he has a 1JZ swap done to his GS300. The 2JZ swap should be a lot easier though.
Reason why all this came up was i was looking at one of my old issues of like sports compact or something and saw that they did a 1J into a 1st Gen GS instead of a 2J. It was saying all this stuff about how much easier it would be because of size of engine and etc.... so thats what got me started thinking about all this. and plus i know of a place to pick up a 1J with tranny for under $2K verses a 2J for around $3200.
My next car needs to seat more then 2 people or else the wifey is gonna kill me. Dunno why she hates both the Supra and CRX LoL. So thats why i was thinking of picking up a 1st Gen for cheap and do this. I know i should probably search more before i put up questions like this. But if anyone can throw any information at me i would be willing to listen.
