SUPRA TT Brakes and Wheel Clearence?
#33
if you wanna rock the brakes in the mean time just get some h&r or kics spacers. both companies make them in small or large sizes. i used a 20mm spacer on my front to push it out a lil.
#35
Its no huge job to bolt up the TT caliper and then try fitting the front wheel. Its the caliper clearance that causes the issues mainly and not the rotor. If it fits and clears job done, if not you'll get an idea for what size spacer you'll need. I am almost certain that any mkiv supra spacer will fit the GS and these should be readily available on ebay if not locally. Maybe this info will help you
NOTE: Supra wheel fitment is as follows:
PCD: 114.3mm
Hub center bore size: 60mm
Studs: 5
Wheel Size Offset
Standard 17" Toyota 17 x 8 front 50
17 x 9.5 rear 50
PCD: 114.3mm
Studs: 5
Wheel Size Offset
17 x 9.5 rear 50
But I have accquired at set of Koening SSR's. Front wheel is 18x8.5 +41 offset. Rear is 18x9.5 and +41 offset.
I also have supra TT calipers and I was wondering if these wheels are going to fit without issues with the brakes.
TexasGS
09-13-06 05:55 PM
