SUPRA TT Brakes and Wheel Clearence?
Does any one know if my new Supra TT calipers will fit my Stock 2006 SC 18" wheels? Just got everything for my big brake upgrade and want to put them on this week and then relised holy shiz i didnt even find out if these are going to clear?
Guest
Posts: n/a
Not sure but I doubt it. Supra TT are huge brakes! Might need a 15mm spacer.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
PM 'Pearlpower' and see if he has any insight, believe he has a bbk on his sc430.
How big of spacer do i get? Man this sucks! Is it bad to run spacers! I know im getting new wheels but is running wheel spacers a bad thing or just looked down apon?
Forum Administrator
The wheel size DOES NOT MATTER unless you're working on a BBK kit with huge diameter rotors. The Supra TT brakes have very large calipers which require a wheel with what is called 'high disk' fittment, which is something the OEM 17" Supra TT wheels have and what ElitistK meant when he said they were 'deep' wheels. The OEM SC430 wheels don't sound like they're high disk.
I called All my local Auto places and they said they dont have a Universal wheel spacer? I got ahold of Big O Tire and they said that they have a 1/4 inch one ? Does any one know how wide i need to go or what size to get?
Its no huge job to bolt up the TT caliper and then try fitting the front wheel. Its the caliper clearance that causes the issues mainly and not the rotor. If it fits and clears job done, if not you'll get an idea for what size spacer you'll need. I am almost certain that any mkiv supra spacer will fit the GS and these should be readily available on ebay if not locally. Maybe this info will help you
NOTE: Supra wheel fitment is as follows:
PCD: 114.3mm
Hub center bore size: 60mm
Studs: 5
Wheel Size Offset
Standard 17" Toyota 17 x 8 front 50
17 x 9.5 rear 50
PCD: 114.3mm
Studs: 5
Wheel Size Offset
17 x 9.5 rear 50
