upgrade brakes/hub studs
Old 05-03-07 | 03:24 AM
jon jon's Avatar
jon jon
Default upgrade brakes/hub studs
just 20's on my GS 400 concerned that the studs are not strong enough cuz wheels are heavier than the stocks i am changing to bigger brake roters should i put stronger studs
Old 05-03-07 | 04:55 AM
DBaristo's Avatar
DBaristo
Apparently ARP do uprated studs not sure where you'd get them though.
Old 05-03-07 | 06:52 AM
jtamulis's Avatar
jtamulis
Don't worry about it, the stock studs shouldn't have any problems at all.
They are a hardnened steel. I've only broken studs by tighting them too tight, or having them rusted, etc. Never from having too heavy a wheel. I've run BIG
tires on my Toyota trucks over the years, on the stock studs without issue.
if I don't break studs on 39" tires, you shouldn't on 28" 8-).
Jeff
Old 05-03-07 | 07:40 AM
hipertek's Avatar
hipertek
just want to piggy back off jon jon, does anyone know where to get extended or longer studs?
Old 05-03-07 | 10:47 AM
jon jon's Avatar
jon jon
Jeff
hey thanks i was just kind of thinking cuz these rims are alot heavier than the stocks i know i need to change the rotors what do u think to eiabach or tien springs ?
Old 05-03-07 | 12:03 PM
jtamulis's Avatar
jtamulis
I don't think you need to change the rotors out, but if you want, both the eibach and tiens both would work well, eibachs would be cheaper. If yo ugo with a big brake upgrade that would be nice but $$$
Good luck!
Jeff
SClawless
GX - 1st Gen (2003-2009)
10-23-17 07:06 PM
LudeNsoL
03-05-10 12:39 AM
Dragnet
11-01-09 03:30 AM
Noypi
RX - 1st Gen (1999-2003)
11-08-07 08:39 PM
GSing430
Suspension and Brakes
04-24-07 11:09 PM
