I recently had the same problem. Bang the **** with a hammer until it comes loose. Trust me. I have the blisters on my finger to prove how hard it is to take it out if it is very tight. I think mine was the original spare that was never taken out. Still had the little ***** on the tire and the colored line in the grooves.
Theres a plastic piece and it sits on a long metal shaft. Is this long metal shaft thats going to spin or just the plastic piece and the shaft never moves?
you need to put pressure on the metal peice..try to use a long screwdriver and put it between the plastic and metal and pry up carefully...basicly what ur trying to do is put pressure on the metal peice to keep it from spinning.
or if u have a pair of long needle nose pliers or vice grips.....that should get er' done!
