offset question-already searched
Old 06-09-07 | 11:40 AM
wide opn's Avatar
wide opn
Default offset question-already searched
hey guys, I've lurked here for a long time, but am finally about to buy some wheels for my GS. I think I found a good set on ebay, but was hoping for some input before I buy.
My car is stock suspension now. I will be doing either springs/shocks or coilovers in the next month.
I want a flush look, but I'm a little nervous of doing much of any body mods just to fit wheels. Also, I plan to run normal camber when I lower the car, so a crazy negative camber setup just to fit wheels is not what I want.
Anyways, here's the wheels that I would LOVE to buy if they will fit.
Lowenhart LS1's
(F) 18x8.5 +19 offset
(R) 18x9.5 +25 offset
I'd really appreciate some thoughts/opinions about fitting these wheels. I've seen some setups on here that are really close sizes to these, but wanted some more input.
thanks,
bret
Old 06-09-07 | 12:40 PM
Tramix's Avatar
Tramix
CL Folding 10,000
Check out these threads. Maybe they can help you a bit.
https://www.clublexus.com/forums/sho...ghlight=wheels
Visuals Thanks to Sieze
https://www.clublexus.com/forums/sho...d.php?t=159062
Old 06-09-07 | 02:46 PM
Seize's Avatar
Seize
Loves Snickerdoodles!
Those will work but you'll need to do some work on the fenders and run a stretched tire set-up.
Here's a link to fellow CL memeber JZZ30TT's set-up with pics. For reference, his set-up is a bit more aggressive than the offsets you've listed.
His specs are as follows
18x9 +13 225/40
18x10 +7 245/40
https://www.clublexus.com/forums/sho...ght=aggressive
Old 06-09-07 | 06:30 PM
wide opn's Avatar
wide opn
very helpful, thanks guys!
lexi90
10-29-20 01:33 PM
YupImJOee
02-25-09 04:39 AM
alister
04-08-08 10:21 PM
DETUNED
Wheels, Tires & Brakes Forum
03-15-04 06:35 PM
