headlight problem
i have one of my headlights brighter then the other i tried to see if it was pointing down so i could ajust it but it didnt do nothin anyone know wut could be the problem
Does the bad side seem brighter when you look from different angles?
I don't know the quality of the kit but you can switch bulbs to try the "good" bulb in the "bad" housing. If it still seems dim with the swap it is definantly the housing or ballast, try swapping ballasts to see if the problem changes sides. I would assume it is an issue with the kit if you didn't have the problem before.
Something is f'd up with the gears for the adjustments. If possible I would take the housing out. At least you could see what's goin on, or just buy a another headlight housing. ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I have someone locally parting out a 94' I will see how much for a headlight.
im lookin for someparts let me kno who is he
Jaybeck860
IS - 1st Gen (2001-2005)
01-27-14 11:08 PM
