New times and dyno in my aristo ;)
Old 07-16-07, 08:50 AM
zazzn
zazzn's Avatar
Default New times and dyno in my aristo ;)
Hey guys,
Went to the track 2 weeks ago and posted a 14.1@ 100 MPH at 12-13 PSI.
Did back to back 14.1's and then track closed as I just got there before closing.
Also dynoed 279 @ the wheels that night.
Mods are intake and profec e01 stock everything else including exhaust.
I then had a full 3" added which splits into 2x 2.5" which currently have the stock mufflers on it and went to another track this weekend (montreal supra meet)
Ran 14.2 @ 103MPH on a hot muggy day. The track prep was non exsistant and really really sucked out of the hole.
Old 07-16-07, 09:03 AM
MDSC
MDSC's Avatar
Originally Posted by zazzn
Hey guys,
Numbers look good, 279rwhp and 14.1 is on stock boost? not sure what the stock boost is.
Old 07-16-07, 12:52 PM
nyARISTO
Sunroof Surfer
nyARISTO's Avatar
wow... hmmm so if u break 300 ur running high 13s ... y dont u go with us spec turbo's(@19psi), Cams, n fuel inj. n bigger downpipe i bet u can run 13's flat
Old 07-16-07, 01:03 PM
zazzn
zazzn's Avatar
279 was at 12-13 psi. Stock boost is 10.
I could have hit a high 13 if I got a better then 2.2 60 foot. but iw as on stock 16" tires, and couldn't really break boost too hard out of the hole.
some 275's and io'm sure i'd do a 13.9.
103 is good for a mid 13 if i get a sub 2.0 60foot
I just installed the emanage and a 3" exhaust, so i should be able to get 15-18 psi on the cermaic turbos. As for USDM cams a little down the road but I probably will get crowers since i have good hook ups with them and get good prices form him and Brian crower.
Twins are a PIA to change if I am going to change i'll just single it, it's easier!
hopeing to get a low 13 with a 112 MPH trap when all setup and tuned out, also hoping to dyno 390-400.
Old 07-16-07, 01:10 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
Looks like you're putting up some good #'s
Old 07-16-07, 01:25 PM
MDSC
MDSC's Avatar
get a converter, put a set of DRs on those stock 16s and hit the track on a cool day you should be in the very low 13s as you sit. I hit 12.9@104.5 in the camaro way back in the day when it was nearly stock, 1.78 60ft ono 17" nitto
Old 07-16-07, 01:46 PM
zazzn
zazzn's Avatar
Yeah i have a few things on the list
-oil cooler
-valve body (stop burning up them clutch packs)
-stock mk3 sawblades with 10.5" to use with my surpa and aristo.
Things that may hurt my 1/4 are coilvers and heavy 18's or 19" wheels.
Not looking for huge power as this is my DD my supra is the guy that takes the trashing.. I just want to hang with the AMG merc's and maybe suprise a few
Old 07-16-07, 04:25 PM
whatthe
whatthe's Avatar
2.2 isn't that bad for an 3800lb. automatic 4 door with only 3.0L and a 2000rpm stall and long gears.
What was your 60ft. on the 14.1 runs?
Do you have the dyno printout and the slips?
Old 07-16-07, 06:13 PM
zazzn
zazzn's Avatar
2.1 or 2.2 on the 14.1 again couldn't break boost more then like 5-6 psi or would rip the tires to shreds.
have the slips and the dyno I can post them if you really want but lazy about it
Old 07-16-07, 08:37 PM
whatthe
whatthe's Avatar
Just interested in the power curve and all the times in between and if it was 2.19 or 2.10 60' that kind of stuff.
Old 07-16-07, 10:03 PM
zazzn
zazzn's Avatar
ok i'll post the slips tomarrow. they are in the car. i'll post up the dynos shortly. I think they are on my computer..
One on stock boost 3gear rolling in to it as it's atuo
one at 12-13 psi again rolling on to it.
looks like it scaled diffrently when i opened it form my winpep at home.. maybe the 5 smoothing. it was 279/300 at the dyno shop
Old 07-16-07, 10:04 PM
zazzn
zazzn's Avatar
and the stock boost one.
Old 07-17-07, 04:06 AM
Epik
Epik's Avatar
hmm.. not bad #s thru the smic.
i have to take a look at my sheet with the twin k26s.. still havent boosted past 14psi.. in fact most of the time i'm running them just shy of boost cut and making about 380. Last dyno before the usdm intake cam swap was 354/343 at 13 psi on stock 440s..
i'm interested to see where my boost hits compared to the stock twins, i never used em. thanks for posting that sheet.
Old 07-17-07, 08:12 AM
zazzn
zazzn's Avatar
how laggy are the k26's do you have a dyno i know how ****ty they where on my 1jz. lagy city but man did they flow up top....
Yeah I've been thinking of doing a china intercooler
SMIC isn't that bad I've seen mk4 guys do lots of power... I do think it heat soaks fast though.
Old 07-17-07, 08:14 AM
whatthe
whatthe's Avatar
Thanks for posting.
I've done a couple of dynos in my time - a few comments you can look into if you really want.
It's been my experience that fuzzy logic controllers tend to have a less smooth power curve (hence the required 5 on the smoothing).
Have you put in some new plugs yet? If not - NGK 6097 - BKR7E
Quick Reply: New times and dyno in my aristo ;)
