oil pan gasket replacement
Has anyone replaced their oil pan gasket themselves ? I have a 93 GS300 and can't tell if the cross member is going to get in the way or not..
thanks !
thanks !
I didn't know there were 2 - I better get my **** under there again and take a look. If it's the upper, is it "doable" ? i.e. what did you have to remove to get the upper pan off ?
thanks..
thanks..
I can handle breaking the seal , but not sure about the crossmember - or maybe you have to lift the engine to get enough room to remove it ? (that's what I had to do on my F-150)
