Fan Clutch? Bad Valvue or Bad Thermostat?
Old 09-28-07 | 12:49 PM
habdelr's Avatar
habdelr
Lightbulb Fan Clutch? Bad Valvue or Bad Thermostat?
Driving back in heavy traffic yesterday, A/C is on and set to 70F and low (outside temp 95F), everything is ok, besides the stop and go traffic, all of a sudden my temp gauge starts raising. I wonder since I had my pressure checked and radiator flushed last weekend. I pull over, no smoke from the radiator (so radiator is still good since its less than a year old), but coolant in the reservoir is bobbling and HOT!
Got the car home. This morning before I started the car, No coolant left, I spun the fan to see if its the fan clutch, I felt some resistance, but I'm not sure.
what do you guys think?!? and anyone know how much those parts cost? and if they are hard to replace?
Old 09-28-07 | 12:59 PM
Kaiser's Avatar
Kaiser
Start with the easy stuff. Start the car and turn on the AC. Verify the electric fans are spinning. Next let it heat up to operating temperature and check the hoses. Are they both firm? Is the top firm and bottom soft? Could it be a small coolant leak reducing your coolant pressure causing you to over heat?
Old 09-28-07 | 01:07 PM
habdelr's Avatar
habdelr
fans are spinning, no coolant leak, and I checked the top hose, and it was firm since i changed it last weekend with the flush... couldn't get to the bottom one since I'm still in my work cloths, i will check it later.
Old 09-28-07 | 01:17 PM
YupImJOee's Avatar
YupImJOee
similar thing happened to my when i had my 88 supra. turned out to be a blown head gasket. same description you gave too. check the oil cap, if its milky with coolant + oil then congrats you have a BHG
Old 09-28-07 | 01:20 PM
Kaiser's Avatar
Kaiser
If the bottom one is softer than the top it could be a bad thermostat. It could also be the waterpump. How many miles ago was the timing belt/waterpump done?
Old 09-28-07 | 01:27 PM
habdelr's Avatar
habdelr
I want to say 30k ago!
Old 09-28-07 | 01:33 PM
habdelr's Avatar
habdelr
BHG???? maybe i should have changed the head gasket when i ordered the parts!!!? I didn't think of that!!!
how can I be sure?
Old 09-28-07 | 01:41 PM
Kaiser's Avatar
Kaiser
Is it blowing smoke? Is there a white milky substance in either the oil or the coolant? Does it idle rough?
Old 09-28-07 | 01:43 PM
habdelr's Avatar
habdelr
once in a blue moon it idle's rough on start up, but normally purrs like a kitten.
and there is no smoke or milky anything!
Old 09-28-07 | 02:09 PM
Kaiser's Avatar
Kaiser
Doesn't sound like a bhg. Check on that lower hose pressure.
Old 09-28-07 | 02:29 PM
habdelr's Avatar
habdelr
Will do.
thanks guys
Old 09-28-07 | 11:05 PM
monkiwrnch's Avatar
monkiwrnch
how's your radiator cap? is the rubber bushing still in good shape? maybe its not holding proper pressure that supposed to.
Old 10-03-07 | 11:56 AM
habdelr's Avatar
habdelr
here is an update on this. I added more radiator fluid to the car, and i have been driving on it for a couple of days. No problem. Last night i went to pick up some friends from the airport, and on the hwy, the temp started rising again? so i pulled over and checked, same thing, the fluid bubbling. We let it sit, and then add a little more fluid, and drove back 30 miles, no problems
So now, I'm really confused
Old 10-03-07 | 12:12 PM
Kaiser's Avatar
Kaiser
Try a 16lb Stant cap for the radiator.
dlcoffin
10-09-18 06:24 PM
Skegeemon
05-14-13 12:21 AM
cheramiear
08-24-12 11:08 PM
durtysc300
Performance & Maintenance
10-16-11 01:06 AM
maxgee
09-27-07 08:16 AM
