Aristo Struts
Aristo Struts
Does anyone have some words on strut replacement options on an Aristo?
My right front factory strut is dead. The car has a nice set of lowering springs and I was hoping to exchange out the strut with a set of '93 GS KYB struts.
It became apparent that the Aristo uses different strut mount/bump stops and maybe more than a '93 GS. Hmmm
Well. All I can find is coilovers and I'm not quite interested in going that route.
2 front factory Aristo replacement struts with shipping from JPN are almost the same price as a set of coilovers.
Couple pics (KYB are silver w/ thinner strut rod)
The Aristos had some sort of electronic control over the dampers, hence the electrical connection. Is there a control in the cabin? KYB's should be a direct replacement; you just won't have electronic control and can leave the plug unplugged. Lot's of the Aussies do this.
Post re: adjustable suspension
http://www.jzs147.com.au/forum/viewtopic.php?t=308
The electronic control is tied into the ECT system. When ECT is switched on the struts stiffen at higher speeds to give a more stable ride.
ECT rocker switch is on the console next to the shifter ... same as a 1st gen GS?
KYBs for a GS do not fit the Aristo .... hence my question. I'm chatting with a JDM parts importer in Vancouver on this issue. Maybe KYB or Bilstein makes a specific strut for the Aristo. I'd likely lose the damper control as people do with coilovers.
I'll keep this thread going ....
johnee78
04-09-05 09:14 AM
