Spark Plugs!!
Spark Plugs!!
I have just went to Advance Auto Parts and purchased some Iridium plugs. I hope that I can install these plugs by tonight. What I would like to know is how many bolts must I remove to get to my spark plugs? And is there anything else that should be changed since I will have to remove the throttle body to get to the wires? Thanks!
Buy some valve cover gaskets and just remove the whole intake manifold. Mine were leaking and I only have 115K or so on the car. It will be worth it if its never been done. So if you do that, make sure and get the manifold gaskets, and your gonna need the gasket between the "Y" and the upper manifold part, if your just removing the throttle body. Clean everything up while you got it apart (MAF, throttle body, all that good stuff).
