rims offset
i would also say it depends on your drop. if you are tucked, i can't see how you would fit anything under a +35. However, a tuck and roll with a baseball bat will get you a lot of room.
I rub just a little bit with a 10" and a 35+. Get an eastwood fender roller and you'll have no worries. My buddy has one just haven't gotten around to it yet.
http://www.eastwoodco.com/shopping/p...&keyword=31158
O.C. Lucky Strike Fanatic
Just to clarify for reference. I am currently running 19x9.5 +35 in the Front and 19x10 +20 in the rear.
My rears were rolled/pulled and fronts are stock fenders.
If I really wanted to push the envelope, I could do +30 in the front( i have tried with spacers and I love the look but didn't do it because the wheel studs are shorter with the risk of hitting my fender).
I used to run +15 in the rear with my old set and could even do +10 to get crazy.
If the offsets are high, in which you in your circumstances, you would want since you don't want the wheel past the fender because of the 1 inch drop.
If the offsets are low, it will stick out for sure because of the 1 inch drop. If you had a drop of 2-3 inches, it would camber.
