5-swap on 1st gen aristo
has any1 done a 5 speed on a jzs147. i dont want to swap out my existing motor which is the 2JZ-GE. Is there any one competent to do this swap thats located in sOcal???
The 7M uses a R154 that can be used if you source the 1JZ bell housing
The 1JZ also uses a R154 but come in two flavors. JDM supra and Soarer.
The 2JZ uses a W58 for the N/A vehicle and a V160 6 speed on the turbo.
Theres a guy here in Houston swapping his transmission, hes putting in an R154, granted he has an aristo swapped engine, not sure if that makes a difference. Im gonna try and keep in touch with him so I can take a ride it when its done.
In other words, yes, it can be done.
You need to do some mods to get it to work. If you have access to a welder then anything is possible.
https://www.clublexus.com/forums/sho...t=aristo+build
