a bit of a tail light problem...
Ok..heres the story.
I went to O'reillys to get a taillight bulb because one of the bulbs were out...ok, no big deal, it happens. I needed the one that was for the Brake/Tail light cause it was the left side that was out.
I install the bulb and then all of a sudden the running lights go out..brake lights work just fine..weird. I check the fuse under the dash, fuse is out..hrm..so i replace it, goes out again...I need to get my *** home, so i put in a 15 instead of a 10 fuse in there to hold me down.
I get home, I notice that my running lights on the trunk are still on, but the two outside taillights are out. I press the brakes and the all brake lights still work.
I take out the bulb and thats when i notice its not the right bulb. Damnit, i thought...his fault, partially my fault for not checking. I get the right bulb, put it in..running tail lights on the rear still dont come on..all brake lights work fine.
I go underneath the dash to see if any fuses are blown and they are all fine...is it a relay problem? if so, where is it? Why is only the running lights on the outer taillights off and the ones on the trunk are on??
i was talking about forcing the bulb into its socket,, bending it so that + and - are touching..thus blowing the fuse every time.. or a blank wire was touching ground every time you closed the trunk/trunk wiring harness in the trunk lid touching ground
problem was...popped the wire.
bigger fuse, strong relay, wrong bulb in place=popped wire in weakest point of the wire.
So I fixed the problem..did a lil re-wire and issue is solved.
but just remember ladies and gents...if u have an electrical issue..check fuse, then relay, then ground, then wire
MJames23
05-07-12 04:52 PM
