clicking noise when turning the steering wheel?
Old 12-21-07, 02:04 PM
Yg_green1
Yg_green1's Avatar
Default clicking noise when turning the steering wheel?
what could be the problem when you hear clicking noise when you turn?
Old 12-21-07, 06:12 PM
LeXusFiTs
LeXusFiTs's Avatar
repeated clicking or a single click when u turn in a specific direction?
Old 12-22-07, 12:25 AM
Yg_green1
Yg_green1's Avatar
single click
Old 12-22-07, 03:23 AM
A.R.
A.R.'s Avatar
Check the plastic Panel by your feet above the pedals. take out the screws and it will just drop off if the black metal clip has come off of the column. Fix everything properly and the click should be gone.
if you have trouble locating it, just turn your car on, get down, and turn the steering wheel and listen for the click.
Old 12-22-07, 08:30 AM
twojayzee
twojayzee's Avatar
Beat me to it.
Old 12-22-07, 02:30 PM
Yg_green1
Yg_green1's Avatar
i look at that and its still making the noise i hear the noise under the car could it be the cv joint or something else?
Old 12-22-07, 02:43 PM
twojayzee
twojayzee's Avatar
GS's are rear drive so it wouldnt be a CV. It could possibly be he u/rag joint on the column. Did you pull the clip down and reinstall it ?
Old 12-22-07, 07:06 PM
Yg_green1
Yg_green1's Avatar
what a u/rag joint but i reinstall the clip now i notice when i drive up to 40 i feel the steering wheel shake and i feel like the back wheel making noise what could it be? i had on 20 inch wheel before now i switch to 18
Old 12-22-07, 07:31 PM
twojayzee
twojayzee's Avatar
Who swapped the rims ? you or a shop ? did it just start making the noise after you switched wheels ?
Old 12-23-07, 01:53 AM
Yg_green1
Yg_green1's Avatar
i swapped the wheels it was my rims i had before the 20 and it start making noise a couple of days later on it makes hella noise when i go up to 40 when i hit 60 itz not really noisy
Old 12-23-07, 08:15 AM
twojayzee
twojayzee's Avatar
So it clicks as you drive also ?
Old 12-23-07, 11:20 AM
LeXusFiTs
LeXusFiTs's Avatar
I think it clicks when he turns, goes over a bump or reverses?! true yes or no?
Old 12-23-07, 12:35 PM
Yg_green1
Yg_green1's Avatar
the clicking is gone when i went under the steering wheel and took of the black piece but now its the steering wheel shake as i hit 40 when i drive and the car shakes
Old 12-23-07, 02:29 PM
twojayzee
twojayzee's Avatar
The steering shaking is either an alignment or a wheel ballancing issue. If the 18's have taped on weights, they could have been knocked off when they were installed.
Old 01-01-08, 09:07 PM
Yg_green1
Yg_green1's Avatar
thanks twojay for the reply i found out what was the problem i had a bend rim .. so now im switching bak to my 20 i wanna know what would be a good setup for the wheels i have 245/35 up front and 255/35 on the rear the car is lower wit eibach
Quick Reply: clicking noise when turning the steering wheel?
