LED interior lighting
Hey all,
I was interested in changing all of my interior bulbs to white LED lighting....
has anyone done this on a first gen?
can anyone supply me with the correct bulb numbers for the interior?
(dome,door panel, the light by the pedals, rear lighting ETC.)
I know there is a sticky in the lighting forum but that is for the sc300.... sre they similar? would the same ones work??
http://www.sylvania.com/ConsumerProd...de/default.htm
Put in you car info it will tell you all the part numbers for just about any light in your whip.
Here is some more that I didn't see on the site that I got from Lexus Boy:
7 x 194 wedge white (all 4 doors, 2 in the license plate, 1 in the trunk)
3 x 74 wedge white (1 in the glove box, 1 under the foot well, 1 in the key ring)
3 x 3022 festone white (1 dome light, 2 rear lights)
2 x bayonet white (2 map lights)
2 x 74 twist socket white (shifter)
That's a pretty cool site, Thanks.
VIP|EXEstyle セルシオ
Although the following link is for the 2GS, you can use it to double check since most of the bulbs should be the same:
https://www.clublexus.com/forums/lighting/71226-98-gs-lighting-information.html
and heres the other link. just do a little search...
https://www.clublexus.com/forums/sho...t=led+interior
https://www.clublexus.com/forums/sho...nition+key+led
