6spd rear end in 1st Gen GS300
This is a list of interchangable rear ends, this info was initially extracted out of clubna-t if you wanted further clarification. I dont see the first gen GS on there so the answer should be no.
Kruso
ps hope this helps
97-00 SC400 3.266
92-97 SC300
6 cyl, AT (4.27 ratio)
6 cyl, MT (4.08 ratio)
98-00 SC300
92-96 SC400
8 cyl (3.92 ratio)
97-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
w/o turbo; (4.27 ratio) Limited Slip
w/turbo, MT (3.133 ratio) Limited Slip
w/turbo, AT (3.769 ratio) Limited Slip
97-98 MKIV Supra
w/o turbo; (4.08 ratio) Limited Slip
Kruso
ps hope this helps
97-00 SC400 3.266
92-97 SC300
98-00 SC300
92-96 SC400
8 cyl (3.92 ratio)
97-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
97-98 MKIV Supra
I think this will help you in your search.
https://www.clublexus.com/forums/sho....php?p=3176544
Kruso
Kruso
thanks for the link that was informative. but i was more curious about the FIRST Gen GS300. not the 2nd.. i know the 2nd supra rears will bolt right on. just seeing if it's the same for the 1st Gen or not?
but it IS CONFIRMED that the SUPRA AUTO TT Differential casing/assembly fits the 1st gen GS300?
Hacked21
SC400 / 300 Classifieds
04-01-15 10:21 PM
