How to- fog light mod?
I Can't remember what wire color but the relay is located on the drivers kick panel in the corner just use a tester and you will find the correct wire to find the correct relay just turn the fogs on & off and put your finger the relay and you'll feel the click.
i did mine today, it took me all of 10 min. to do.
What i did was tap into the power wire from the parking light right at the connector and ran a wire about 8" long strait down to the fog light and taped into the power wire on the fog light connector and thats it your done.
the only down fall is that the switch for the fogs is no longer functional. so theirs no turning off the fogs when the parking lights are on.
EDIT:
your also going to upgrade the parking lights fuse from a 10amp to a 15amp cause the fogs run off a 15 amp circuit
EDIT:
elsmooth
08-06-10 07:05 PM
silencer92
SC- 1st Gen (1992-2000)
14
04-30-07 06:21 PM
ryanSC400
11-26-06 05:13 PM
