Engine Flooded Whats Going On???
I'll try to make this as concise as possible. My engine gets flooded with fuel to the point where is shuts off. In order to turn it back on, I have to pull the TB, plugs, and crank it so that gas shoots out the cylinders. I've replaced plugs, wires, rotor, cap, distributor, injector o-rings, I swapped ECU's with my manual SC. Well last night I think I found what is causing the problem. When I turn the key, the injectors prime, but never turn back off. In other words I have constant power on all 6 in injector clips at all times. Any clue as to what's causing this? I'm going to try to pick up another GS ECU on my lunch break. BTW it's a stock 93 GS.
BTW: no matter what you find out. You should definatly change your oil. You dont want the fuel to wash out your oil and burn up the rings.
How do know the injectors arent turning off ? If thats the case, you would have a very, very large pool of fuel coming out of the seals in your motor.
Bypass the fuel ecu in the trunk. You will need to jumper two wires to do it. I don't remember the color codes right now, but there are two different sized wires in the loom. It's two larger ones right next to each other.
Already did that. I know those things fail from experience with my SC.
I replaced the ECU with one from another GS tonight and it wouldn't run. Just backfired and shut off.
I've never been stumped like this before. Could something in the harness be causing this. ??? Aside from the motor the harness is the only thing I haven't replaced.
Injectors were all tested and are in proper working order. I even pulled the entire wiring harness to check if it might have grounded itself somehow. That thing is bullet proof though, and I found nothing. At this point I have no clue what to do...
