2jzgte motor mount fit in our car????
here it is, from August 07
If you are wanting to use the Supra TT mount, it will lower the engine in the bay 1/4" (better handling, due to lower center of gravity) and they are not liquid filled like the GS mounts.. therefore stiffer and transmit more vibration. It is not bad, just not super smooth like the Lexus.. more performance minded like the Supra. Buy the 97 Supra TT mounts.
The hole for the stud that goes thru the lower attachment point in the subframe is what will need to be enlarged. If you can get a good look at it, you can see the size it needs to be bored out to. There is 2 layers of metal on the subframe around the stud hole. The inner is the smaller diameter that matches the Lexus stud, the outer layer is the larger one that matches the Supra mount stud. The subframe in the GS is steel.. unlike the SC that has an aluminum subframe, so be prepared to grind..
My experience is with the GTE engine, not certain if the upper stud hole on the aluminum mount for the GE is the same or will need to be bored out.
DroppedGS
GS - 1st Gen (1993-1997)
12-30-03 12:33 PM
