What coilovers are YOU running? Which drop the lowest?
#76
nice!!
I just installed my D2 racing ones a few weeks ago. Rides nice, I dunno..i like it! its low too!
Its pretty similar to the megans and Ksports..I believe, but never really compared.
I got d2 cuz someone local was selling a brand new set for a good price, it was actually for a MKIV supra but it bolted up directly with no problems.
#77
nice!!
I haven't had time to install the front MR coilovers yet, they are still sittin on HKS LS+, but I like the ride stiffness on the MR vs. the HKS. I'm too used to my AE86, all stiff. HKS spring rates on the LS+ is 9kg/7kg I believe, and the MR are 14kg/10kg.. I like it a lot!
#79
if you're asking because you want to fit the HKS LS+ with the you UAS you have, yes, its will fit. but if you're not asking for that specific reason, I'll measure it and find out.
#80
I'm running on Cusco Zero-1 coilovers. They're are really nice if you want a stiff ride. It's a full tap coilover so I can pretty much drop the car to the ground if I wanted, also it allows you to adjust the height without worrying about changing the spring load. They are pre-set when they arrive and have adjustable dampening. Also has an anti-rust protection on them. Definitely a recommendation and they don't hurt the wallet too bad either. They go for about $1600
#81
#82
I wanted to go coilovers + air susp. too, but I think I'll be 2JZGTE'd before that, hopefully before the end of august. I'm comtemplating.. 6 speed, or Auto. I want to go auto, just because my 86 is my fun 5 speed car. But my friend is trying to convince me to go with the getrag 6speed. I already have a guy is doing all the work for me. Now I just gotta decide, auto, or 6 speed, if I go manual on my GS, 6 speed is the only way.
#83
sup joey..
for sure.. but it wont be started for awhile (maybe couple weeks). I'm looking for a aristo clip, gspeed has none right now, do you know any places around socal that sells engines, besides C&T engines in Ontario?
but for sure i'll let you know wasssup..
#84
Hey vipguy, did you have to replace the bolts on your JIC's to fit the Aristo front strut bar? If so, what size are the bolts? I too have the flt-a2's and tried installing my stock Aristo front strut bar but the bolts were not long enough. Any help would be greatly appreciated...
JIC's set to stiff, if not I would bottom out being as low as it is, its not too harsh because im running 18's. Takes corners very well without rubbing also...
#85
I'm running Tein HA's.
the spring rate is retardely high, but still decent enough for daily street driving. on the firmest damper setting, you bounce around alot, but i dont' mind them at all
they're not even on the lowest setting, i could go down about an inch more, and my exhaust cutout is currently 2.25" off the ground
#87
