Headlight adjustment help!
Hey everyone i was wondering if anyone here know how to adjust the height of the headlight beam??? well the problem was i dropped my gs300 and now the height of the beam is pretty low and i want it to beam a little higher...i was wondering if anyone here have a diagram on some sort of picture of where to adjust or know where to adjust? thanks if anyone could help...
there is a screw behind the headlights. park your car in front of a plain wall or your garage door, remove battery from driverside and the airbox from the otherside(or if you have a very short screwdriver, you can skip the removing part). there should be a green liquid leveler on top of the headlights. find the screw directly behind the lowbeam, find it and turn it and the bubble in the leveler will move. i forget if you turn left or right to go higher, but you can find out by trial and error.
i had to lower my headlights because oncoming cars keep hibeaming me after i installed HIDs(damm crybabies).
jagtoes
ES - 5th Gen (2007-2012)
12-14-14 11:58 AM
