Negative Camber After the Drop
So guys,
I have a few questions for those that might have answers![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Just recently dropped my car on Tanabe DF210's like many others here recently and went to go get an alignment. I know that our suspension is adjustable even though the give is very little which is why I went in the first place. Now, right after dropping I had about 2.5 - 3 degrees of negative camber on each wheel and after my alignment, about 2 degrees on each wheel.
I've searched the forums and know that there are camber bolts available for our rear tires, but no camber kits for the front. Has anyone figured out how to fix negative camber in the front (the posts I read were from 2 years ago)?My questions is, is 2 degrees of negative camber substantial? Should I get the camber bolts for the rear tires and check/update my casters and control arms up front?
The Tanabe's drop our cars about 2 inches. I just want to make sure tire wear isn't EXCESSIVE because without a doubt there will be extra tire wear because of the camber, I just don't wanna replace tires every 3 months.
Thanks,
Rob
Thanks,
Rob
really? 2 degrees is enough to really wear them out?
my casters and cross camber are all within -.5 degrees.
I'll invest in the eibach camber bolts for the back, but is there any solution to front camber issues?
Lots of people are dropped on these forums, its hard to believe that so many people have been swapping tires like underwear cause of camber. And mine is only 2"!!
More than 1.5deg is going to cause signifigant wear on the inner lip of the tire. More important than camber is toe adjustment.
The caster on our car isnt technicaly adjustable, though you can get a minor amount from moving the k-frame, theres no need to do so. Do you mean at all four corners you have -.5 deg camber ?
but Wow... for 150 I'd do it too...
also, anyone have any experience with the rear camber bolts available for our cars?
hey guys, i'm having the same issues due to my drop. anyone install those eibach camber bolts?? here's a link to them: http://www.sfxperformance.com/parts/EIB581270K.htm
they're pretty cheap. input anyone...??
The Eibach camber bolts for the rear came with my Eibach Pro kit, but I wonder of there was a packing error because they don't work on the car.
2 degrees up front will cause inside wear on the tires. You can counter this by running more PSI (like 37-38) to crown the tire a little more, but that doesn't seem to do much. You can also flip flop the tires from side to side periodically to extend tire life.
In other news, my brother is on the road now on the way back from SEMA. On his list of people to see was an Australian company that makes camber kits for the 1GS. I'll talk to him and one of us will report findings here.
I've been running mine without any alignment since I put on my 19" Volk. I was kinda lazy and still wanting to wait until I get a new set of coilover. It's almost 1000 mile since putting it on and I can tell that it is wearing from the inside already. I have Nitto 555 Extreme at the moment and the thought of replacing those suckers freak me out since it is 19". How are the rear camber kit from Eibach? Is there any other solution for the front? I tried to cheat a little by putting lots of air like 40PSI just to crown the tire out a little more but that won't help much.
My rears are 20's and they have been holding up pretty good. im at 3 months and ready to flip flop them. Keep in mind my car is a daily and I put in about 15 to 30 mi daily. I'm now seriously thinking of adjustable front upper control arms to adjust the suspenion even more... 700 for a part that will potentially make my tires last longer now has become a very reasonable investment.
