Side mirror signal and floor lights
Old 05-15-08, 09:52 PM
brianfung
brianfung's Avatar
Use the super bright plate mounting LEDs.
More picture added, comments please...
Old 05-15-08, 09:53 PM
brianfung
brianfung's Avatar
Originally Posted by twojayzee
We are intrested in the diagram. The auctions ive been looking at with the switch and relay box, look like they have quite a few wires.
Oh and another question I just thought of. Do you know if the JDM mirror glass and USDM can be swapped ? I like having the objects in mirror are closer than they appear.
Diagram Posted. https://www.clublexus.com/gallery/sh...17055&cat=4379
Old 06-03-08, 09:02 AM
brianfung
brianfung's Avatar
More pictures posted:
https://www.clublexus.com/gallery/sh...y.php?cat=4379
Old 06-03-08, 11:38 AM
twojayzee
twojayzee's Avatar
Originally Posted by brianfung
Is your car already and aristo ? I thought all the RHD's had folding mirrors ?
Old 06-03-08, 05:22 PM
brianfung
brianfung's Avatar
You are not 100% right. I am in Hong Kong and all the official dealer model are identical to an export model, same configuration to the model shipped to US except for the drivers side difference.
I have recently got it repainted to color code 4T5 (the color code from LS460)and replaced with an Aristo model front bumper to make it look a little more sporty. Of course, the wooden plate decoration are replaced from an Aristo model too may make it look a little more like an Aristo.
Old 06-06-08, 10:08 PM
brianfung
brianfung's Avatar
The diagram https://www.clublexus.com/gallery/sh...17031&cat=4379 is just the control to a relay (the K component). The relay will control the open and close.
The circuit is just to make the open and close controlled by a push button instead of the on/off switch. The 4 wires from the motor of each side mirror are
Yellow+/Green- = open
Brown+/Blue- = close
With this circuit, you can make the mirrors to open when you turn the key on and close when you off the key. You don't even need to press the button.
I gave up the tail fog light switch and used the same size "mirror vibration" button to control the mirror open/close. It looks like genurine stock mirror control. See this one https://www.clublexus.com/gallery/sh...17648&cat=4379
The mirror angle control is not changed, you need to connect the three wires back to the plug used by you old mirror.
The LED turn signal and the floor light from the bottom of the side mirrors are connect separately. If people are intested, I can provide more info.
Old 09-08-09, 11:37 PM
ehong33234
ehong33234's Avatar
my gs430 has the illuminating side mirrors that light up on the bottom when you get near the car with the sensor key or if you press unlock. can you think of a way to rig the wiring so this light also acts as a turning signal blinker when I drive?
ehong33234
09-10-09 08:47 AM
midnite c
Lighting
01-15-07 03:35 PM
brian lin
SC- 1st Gen (1992-2000)
17
06-06-05 10:00 AM
Quick Reply: Side mirror signal and floor lights
