Maintenance and repair 93 GS300
Ive had my 94' for 7yrs or since 114k. The only thing I did was a timing belt and water pump the day I took it home. Since then just oil changes, front pads once and sent my gauge needles out for repair to lextech dot org.
EDIT: I only have 185k on it now though which is low compared to some of the 200k guys.
I dont remember what the manual recomends. But it should go like this.. Timing belt and water pump (relatively cheap if your mechanicaly inclined and DIY) Serpantine belt (super easy) Sparkplugs, cap and rotor and air filter. Check the brake pads etc.. If you DIY. You could get away for under 300bux using genuine toyota parts.
I read this @http://consumerguideauto.howstuffworks.com
NHTSA Recall History
1993-94: Spherical portions of certain lower ball joints are not smooth, causing friction that can lead to ball joint separation.
1995-97: Due to inadequate lubrication, excessive wear can cause damage to lower ball joints; separation from steering-knuckle arms could occur.
And I've also came across some threads that say these MUST be replaced Anyone have problems with these issues?
So what does that mean and what does it consist of doing? I think i read the DYI info a few threads ago...but how can i tell if it has or hasn't already been done sounds major.
Oh on the other hand I did find out some more info GS300 i was thinking about getting its a 93 with 156k miles and one owner asking 6299.
What all do you have to do to the upper arm...is there any DYI info on it or photos. Oh and how many actually put premium gas in their cars at these prices....?
stopped driving the car all together, drivin my dads 4 cyl until i get swap in the lex. then it will be a play car
I always put premium. Its only a few bux more. I can feel my wifes gs430 pull timing and hear it ping if you put crappy gas in it.
EDIT: oh and thats why I have a motor-sickel. 46mpg baby
