My rear drivers door wont open. Any Idea?
I had a similar problem on a corrolla which was the outside rod came off and the child lock was left on so from the inside nor the outside it wouldnt open. Now I've bought a gs300 and the rear driver door wont open I can't figure it why. The child lock switch is also hard to spin from the inside making it hard to figure if that could be a solution. Have you guys had anything similar problems to this in the gs 300 or if you have a solution to this. I've tried removing the panel but it won't come of since its nearly impossible since door won't open. I do hear the door click the switch open when unlocked and lock. So mainly it could be that a rod fell, and the child lock was left on. Any help would be appreciated.
SLVRGS
GS - 1st Gen (1993-1997)
05-01-03 01:15 PM
