Another wheel offset question...will these fit?
Looking at a set of wheels 18x8.5 with 30mm offset and 18x10 with 24mm offset. How will these fit? Any rolling needed, not really looking to do a pull.
Thanks fellas..I'll get this offset stuff down one of these days
The fronts,no problem.it will fit.
The rears,if you roll the fenders flat it should clear.that's if you plan on using stretched tires.if not,then a slight pull maybe necessary.
Is it possible to pull the fenders myself or is this better suited for a body shop? I should be able to get my hands on a fender rollers so what size tire would I need if they were to be stretched and to fit?
the rears will fit, i'm running a 10.5 with a 30 offset, so they'll stick out a bit more than mine, you'll just ahve to stretch the tire, and crank up your damper setting on your coils
