Aristo Engine Swap Problems. Need Help.
Hey, some of you might know my car is undergoing an Aristo engine and transmission swap.
I went to check up on the car today and the tuner that is working on it is having a problem that he was hoping someone on here could help with. Hes done hundreds of engine swaps, and has a guy in Japan helping him, but still cant figure this one out.
So basically the car fires up and will start for about 3 seconds, then it dies. He has changed everything, almost every sensor on the engine is new, it has new coilpacks, the fuel is flowing perfect. it has every freakin thing it needs to run, but it just wont run. We are thinking it could be something with the wiring, maybe a circuit is messed up. im not sure, if anyone has ANY idea at all, i will forward those ideas to him and maybe you guys can help us with the problem.
Thanks!
Thanks!
coolant temp sensor on the water neck for the upper rad hose. my car did exactly the same thing when the wires got dryrotted and snapped off the last time i pulled the engine.
there is no polarity, so just make sure they are connected. brown 2 pin plug.
this coolant temp sensor is for the ecu to use to base it's start fuel map off of. better check your sparkplugs too.. most likely wet with fuel.
Ok so i came back from the shop today and EVERYTHING major is ok, all sensors are perfect, coil packs are perfect.
there are 2 things we think may be causing this problem we still have.
1) i had an aftermarket stereo installed before the swap and was giving me no start problem for a while, that may or may not be it.
2) we think the ecu is not seeing the fuel injectors and not telling them to fire, its getting voltage, but not signal.
a few questions, can i just take the factory alarm off?? because after i got my stereo installed the alarm was goin crazy. so could i just take it off? is it easy? and what will that affect?
also anyone got any ideas on the fuel injector problem? i think hes going to trace the wires and see if he can find a short or something.
but thanks epik ill let him know about that too, i think the sensor is fine but ill let him know anyway, any help is appreciated.
the fuel pump and all the lines work, but something about the ecu not seeing the injectors and not telling them to give fuel. the pump is a denso one for a mk4
