TRAC light
TRAC light
Hello,
1993 Lexus GS300. I'm having a problem where the TRAC light comes on during the first start of the day. This happens maybe 2 times a wk or so. When the light comes on, the car hesitates off stop lights. To make the light go away, I simply re-start the car....and the light does not come back on for another few days or so. As mentioned before, the problem only seems to happen when i first drive the car in the morning.....and again, its only happening maybe 1 or 2 times a week.
Any thoughts on what could be causing the problem? Any help is greatly appreciated. Thanks.
Just some input to consider.... I recently had a similar problem, trac light would come on when I hit about 35 mph and I could hear a noise like a pump trying to engage. Ended up having to replace the ABS accumulator unit (will also need 1 other piece and some O-rings). Alot of these TRAC issue threads go with no follow up but I've seen one other member who had the exact same symptoms/repair......but it could be other things too.
CheVelleSS
Performance & Maintenance
12-14-13 03:30 PM
johnnybmw1
SC- 1st Gen (1992-2000)
06-11-09 11:40 PM
jgarland
GS - 1st Gen (1993-1997)
02-25-07 02:15 PM
