hp+gas gain or scam?
i was lookin around for a air kit under 2k and i ran across this:
http://www.streetbeatcustoms.com/Sur...ce-Chip/17558/
Or do you guys know of a better ecu chip?
It's just a potentiometer. It interrupts the intake air temp sensor and deceives the ECU into believing it's cooler than it really is outside thus altering the calculation for the load map. You could do the same thing with a .40 resistor from radio shack but it's not worth it. If you want more timing, turn up your distributor to 14 degrees. It's free.
frankjames
Performance
06-07-07 10:46 AM
