help on removing the rear deck
Whats going on LEX Lovers, i need help on how to take out the rear deck also i want to change my speakers from the doors can anyone help me and tell me how to remove rear seats, rear deck and door panels, this might be a few dumb questions but i dont want to damage anything. Get back with me at my email today_org@yahoo.com thanks
the rear deck is easy, on the bottom seat, you just lift up, and it'll pop right out of it's retainer clips. pull it out of the car.
then the back of the seat, simply undo 4 bolts that are located at the bottom of it. you'll see them, there's 2 by the seatbelt buckle clips, and 2 that are on the outside by the doors. You might have to lift up the carpet slightly to get at them. you then just lift the seat up, and out.
you'll be left with 4 white plastic clips i do believe holding the shelf in. pry those off, and ten lift the shelve. you should then be able to see the connector for the 3rd brake lights, unplug and pull the shelf out.
snicksnug1
12-19-06 08:26 PM
hotnikes
07-11-02 04:07 PM
