Rear windows not working
ok heres my situation when i bought the car the rear pass. window never worked so i pulled the door panel of to test the motor with direct power and it worked so i figured the master switch was no good.,fine so then not to long ago the other rear window stoped workin so i finaly bought a used master switch thinkin thats the prob. so i finally got the switch and put it in and sure enough it dont work so my question is what the hell is the prob.?
i checked the book for fueses but theirs nothing for the windows can anybody tell me what else i should check,... please
AhHHH check the wires between the door for some reason the wires get brittle and due to the open & close or the door they break, what i found with my gs is that the wires did break but the sheilding was intact so u might have to strip back the sheilding on the wire to see the damage
