Tomorrow I am.......
Tomorrow I am doing following...
Drain and fill transmission fluid (Toyota T-IV fluid)
Drain and fill differential fluid
Drain and fill radiator ( toyota pink antifreeze )
Change oil ( VALVOLINE 5W-30) and filter (OEM TOYOTA)
Changing serpentine belt (timing belt and water pump are good and motor mount have been changed 10 000 miles ago)
Anything I am forgetting just would like to prepare it for winter it is a 1993 GS300 with 227K on odometer thank you.
at work when we do 30K services...we change the brake fluid in the reservoir and when i changed mine the GS i noticed that green algae was growing in it...to solve this suck out all the brake fluid. unscrew the bolt that holds the reservoir down. pop it off and use a crap ton of brake cleaner to get it all out...all clean now!
oh and the check the floor mat sensors...ours tend to go bad all the time.
RG3toDC
10-28-18 03:07 PM
Iluvlexus
Hybrid Technology
12
01-14-13 07:46 PM
