916rwhp 780ft/lbs
#32
THey have been proven to hold 1000rwhp....just not very long. I remember reading about a guy who ran his car for two seasons on 1000hp before he finally bent a stock rod. But that is VERY dependent on tune and TONS of other variables. I am just going to run these until I blow it up, then have my built motor ready to swap in.
#34
I do have some JE pistons, but the rods are the weak link, not the pistons. I did however use ARP rod bolts, but again, the actual ROD is the weakest part of the stock 2J motor IF you don't detonate. I only added the pistons to pevent breaking due to detonation. The pistons are actually hurting me HP wide and I would have run more with less boost on stock pistons. Car sounded 100% better with the High compression too. The original #6 had some pitting from a foreign object so I just replaced them all with spare USED parts I had laying around.
#35
#36
Higher compression. Better thermal efficiency. Boost would aslo come on much sooner.
I remember the first time I started my car with the X-trim wheel and 272's on 9.3:1. It sounded awsome. The pressure coming from the exhaust was insane even at idle. I had to pull the motor apart shortly after that due to a BHG(from welding on head and not resurfacing) and put it back together with the 8.5:1 pistons. So now I am at like 8.3:1 and possibly lower. The exhaust not is VERY LAZY now and doesn't sound near as good.
My race motor will be 11.5:1.
#37
Well leaks and I improved the efficiencey of the air going into the head.
Havn't really had time to update my website. It is quite stale. Someday maybe.
Here is a more detailed spec on the car.
1993 GS300
235,000 miles on chassis
Here is the car.
1993 Lexus GS300
235,000 miles
Engine:
3.0L I6 2JZGE
stock rods with ARP bolts
JE 8.5 pistons
Head:
TT 1.3mm HG
ARP head studs
HKS 272 cams
seat blend and port cleanup
Turbo:
74mm ITS turbo
XSPower Manifold
XSPower 3" intercooler
Tial 50mm BOV
Tial 38mm WG
Custom piping
Custom intake maniofold
Q45 Throttle body
Custom stainless 3 1/2" downipe
Custom stainless 4" from downpipe back
fuel:
1600cc injectors
Weldon fuel pump
-10 gravity feed
-8AN from pump to dual -6 rail (too small)
Runs on E85(E70)
Electronics
AEM EMS
AEM Wideband
AEM boost controller
Drivetrain:
Custom Manual conversion
1988 turbo supra 5 speed transmission
stage 3 clutch(no where near strong enough)
stock driveline(with exception of front half for new tranny)
stock rear end with 4.10 gears
stock axles
285/40/17 tires on Jupiter 3piece wheels
Future plans:
Full roll cage w/chute
Powerglide
600lb diet
Powerglide with 6,000 stall.
More power!!!
1993 GS300
Here is the car.
1993 Lexus GS300
235,000 miles
Engine:
3.0L I6 2JZGE
JE 8.5 pistons
Head:
TT 1.3mm HG
ARP head studs
HKS 272 cams
Turbo:
74mm ITS turbo
XSPower Manifold
Tial 50mm BOV
Tial 38mm WG
Custom piping
Q45 Throttle body
fuel:
1600cc injectors
Weldon fuel pump
-10 gravity feed
Runs on E85(E70)
Electronics
AEM EMS
AEM Wideband
Drivetrain:
stock axles
Future plans:
Powerglide
600lb diet
More power!!!
