Frnt Susp _ Lower Contral Arm #2 Removal
I go to remove this supsension component to replace the bushing and I am myphed at how to do it. It looks like the piece is bolted from the top through the sub frame. I can't believe this to be the case so I am asking for some assistance, I am obviously missing something here.
The problem is the bushing on my passenger side is cracked all the way around and I figure this has to hurt stability and probably adds to the clunk factor of the car. Any suggestions appreciated, see pic below the part I am refering to is circled and I previously asked if anyone knew the name. Thanks!
kinda hard to tell in the pic but it looks like the caster arms your pointing at. from what i've read before other members have dropped the subframe to get to these
Removal
You may be right, I think you can adjust caster with some sort of shim. The diagram calls it lower control arm #2.
Question is how do you remove it. Bushing which is to the rear has cracked and needs replacement.
