Brake Bleeding Question
I have a 93 GS, and plan on changing the brake soft lines soon as well as flushing the fluid out and replacing with ATE Blue. The calipers are stock OEM for the car.
2 questions:
1. Can I use stainless lines meant for a Supra? TT or NA version? Any recommendations ?
2. My car has traction control; does this affect the standard bleeding procedure? Same question re: the ABS system. The shop manual is kinda vague on this topic, to put it lightly. I have noticed that it introduces more doubt than confidence in performing jobs myself on this car.
Thanks
Ken
2 questions:
Thanks
Ken
SS brake lines
You will want to use SS lines for your model car. everything I have read indicates the Supra lines are to long.
Horsepower Freaks sales SS for the GS300.
As far as bleeding with an abs system, I need to look into that. I want to say you should be able to perform the same procedures as normal.
What does your manual say?
Goodridge SS lines for a TT
Techna Fit SS lines for a GS from HPF, they have the PVC coating (mine are clear) and they have worked just fine for 6 months now.
TT lines are too long. You can zip tie them out of the way but I'd rather just go with one the right length...unless you need the extra length for something. Bleedings just the same. Pump a few times, hold it, open/close the bleeder valve, repeat. Start from rear passenger, rear driver, front passenger, front driver. Someone may need to confirm that last part but I thought you're supposed to start furthest away from the master cylinder.
Could someone please measure the length of the GS kit in a pre-installed state.
I currently have fronts installed on my LS that are to short & halted my project.
Correct LS versions were then sent to me so I need to mate the uninstalled rears with the free floating fronts (not in bracket) I have been running & see what Lexus they do fit.
I get to re-do the install with proper length lines. Pain in the *ss!
DJ8684
GS - 1st Gen (1993-1997)
02-24-14 06:27 PM
shaitaan
Suspension and Brakes
11-21-06 07:16 PM
