Aristo DRL question
Aristo headlight wiring question
PROBLEM SOLVED Thanks for everyones input and putting up with my noob-ness
Am I able to make the JDM turn signal do as the USDM parking does? Just stay on and blink when the signal is going? And wire the DRL to stay on with the "desired parking light". I think its illegal to not have the amber lights on while driving isnt it?
Could I leave the turn signal how it is, then connect the hanging green wire from the USDM harness to the green wire on the DRL, then the white wire from the DRL spliced into the white turn signal wire? Or would that cause the DRL to blink with the signal? What do I have to be cautious about as far as overloading anything or blowing fuses/connectors?
Forgive my noob-ness, but I am just TERRIBLE with electrical and always have been but I thought I'd be able to handle this considering it's only a couple of wires, but I ended up with my taillights being out when I turn my headlights on (brake lights still work when brake is applied though).
Ok, I just tried this and the DRL still doesnt come on and my tail lights are still out
I have the green DRL wire going to the old parking lamp wire, then the white DRL wire (I used black wire to extend it) I attached to the white wire from the parking lamp/turn signal....but it doesnt work. Should I move the white DRL wire to the white headlight wire?
bump!? I've already tired 3 ways and none of them worked, still unclear and I dont want to just start cutting into wires trying things. Should I splice the "black"(white DRL) wire into the white headlight wire and leave the rest the way it is?
What you have done looks like it should work, in principle. White/black stripe is always a ground path on these cars, so having both lights grounded to the old harness ground looks to be correct. Everything you have done seems to make sense. I notice that there isn't a hint of solder anywhere, which makes me doubt the stability of those connections.
Should be no issues with overloading. The spliced wires are going to have a little more current when the DRLs are on at the same time as the turn signal, but these are low-watt bulbs with intermittent duty. Can't imagine a problem there.
The loss of your taillights makes no sense. That circuit is driven by the main light switch, but the current path is not dependent on the function of the DRLs I don't think. My schematic is at work, so i can't look at it till tomorrow.
That's not how they'll be connected, just doing that to see if they work. Tail lights stopped working after I snipped the corner bulb connector and when I put in the Aristo one, I left the smaller green wire with no black stripe (parkling lamp wire) unattached to anything then that night I noticed the tail lights weren't on anymore
why not just run a new DRL relay from ignition i think, and run a line into the fuse box with a fuse. that's what was done on mine for OPI.
the only DRL i have now, is my vanity plate since i took out the bulbs for DRL's
will i have this same problem to cuz i just ordered a set of jdm for usdm replacement? or not just cuz im using my 2 headlightas and i signal bulbs not that "fourth" light that jdm has
Problem solved The way I wired it the 1st or 2nd time ended up blowing the tail light fuse. So wiring it the way I did the 3rd time and replacing the fuse solved the problem. So I guess the final word is that the turn signal on the Aristo lights can't be made into a parking light as well?
GS300cky: wire it the way I have it in the only remaining picture and you'll be fine
Well dont bank on me wanting to sell them soon. I may as a spur of the moment thing but I lowered the rear some more to about .25/.5" from the lowest setting and Im actually pretty happy with the stance. It's not super slammed but I dont have to worry TOO much about speed bumps and dips, etc. I'd like to go with air but considering the ~3k price tag, Im probably going to end up keeping these for a year or so. So dont "wait up" but I'll definitely shoot you a pm down the line when/if Im ready to get rid of them
