timing belt/water pump everything??
Is this really everything I need to do this??
http://cgi.ebay.com/ebaymotors/ws/eB...0592&viewitem=
Water Pump- Compete Unit with 2 Gaskets
Premium Timing Belt
Tensioner Roller
Hydraulic Tensioner
Front Camshaft Seals
Front Crankshaft Seal
Thermostat with Gasket (OEM Temp)
It doesn't have the lower or upper timing cover gasket, are those reusable?? When I look at the expanded parts view on say trendmotion it looks like I need those as well.
Searched and could not find a list of exactly all that I need.
also putting in new spark plugs for the tune-up, changing the diff fluid, and trans fluid.
Premium Timing Belt
Tensioner Roller
Hydraulic Tensioner
Those are the parts you need. Might want to do fuel filter while your at it.
Don't know if you've ever done one, but some use a paper clip for the tensioner. I've never found one strong enough. A small allen wrench works best for me.
SteezyLS98
12
11-23-15 08:02 PM
Och
05-15-06 08:01 PM
