Another visor Q. Searched.
Old 03-26-09 | 12:39 PM
mkiiisupra's Avatar
mkiiisupra
Default Another visor Q. Searched.
So I got my visors on and I was going to put the clips in and Im aware they go between the seal and window frame, but mine wont go in. I can get about 1/4 inch in, then they stop.
I was just reading a thread about how they screw in (which would explain the 2 little holes on them), is this true? If so, how are you supposed to get a screw in? I was also reading you're supposed to put the clips on first then put the visors on and finally connect the 2 after they're both mounted.
Currently they're taped on and I figured the clips just slide into place, but it's happening that way. Are the clips even necessary? Could I just pull off all the clips? I've been pushing and pushing at them but they wont slide in completely, I can get it about 1/4 inch in then they just stop, no matter how hard I press. My fingers hurt from pressing on the thin metal so hard, but they wont budge. Any help?
Old 03-26-09 | 03:24 PM
AaronStaub's Avatar
AaronStaub
I assume you are trying to do this with the windows rolled down? They simply slide in. Mount with clips, remove backing from tape, press into place. no screwing.
Old 03-26-09 | 08:54 PM
mkiiisupra's Avatar
mkiiisupra
hmmm, I've tried just that but for some reason they dont want to slide in. I took a break so hopefully I'll get some luck and it will work right away. But I figured it shouldnt be complicated, stupid issues. Thanks.
and yes, windows were down.
LRP_LS400
Automotive Care & Detailing
06-17-10 02:10 PM
Durrby
SC- 1st Gen (1992-2000)
03-16-10 10:06 PM
KiPod
14
05-05-09 07:00 AM
mkiiisupra
03-26-09 12:48 PM
Rich27
02-19-09 07:49 PM
