Code 21 and Code 71
Code 21 and Code 71
My car is throwing these 2 codes. Any more information on these 2 codes and how to fix it?
Thanks.
PS Car is smelling like gas pretty bad at idle in the garage.
Thanks.
21 is main O2 sensor and 71 is EGR malfunction:
http://www.troublecodes.net/Lexus/
My guess is the O2 sensor has more to do with the gas smell. The guys at Dynamic Auto Services told me that 71 is frequently the vacuum modulator, which is about a $60 part.
i actually just did my o2 sensor 5 min ago... EASY!!!! the book says mechanics get 2or 3 hours for it and it took me only 15min
but see if someone can hook it up 2 the scan tool and pinpoint the exact o2 sensor cuz list is 196 unless you have connections... so if you wanna spend $1000 and do all 5 O2's you can or get a buddy in the field then it will cost you only 75+tax
i used a denso(oem) one i will get you the part number 2morrow cuz my box is on my box still
2 o2sensors on your exhaust manifold (1 on each side) then 1 on your exhaust by the cat and the other 2 are a mystery 2 me... i didnt know about those other two someone can correct me if they know more
sorry for the wait on part number but its a 234-4624(denso)
heres the denso web addr. http://www.densoaftermarket.com/cata....php?part=o2sn
ok so i checked and there is only 3 O2 sensors on the gs. i dont know if theres more on the 96-97 but on my 95 its 3 so 1 on each side of the exhaust manifold and one on the cat area
how to remove
-buy some PB from kragens or your auto store
-get a 22mm wrench(i think, someone correct me)
-3 o2 sensor
two are location at the exhaust manifold, other is at the catalysis convertor
spray PB on the o2 sensor to loosen the screws and open it
replace O2 sensor with new ones
than...bam...your done
-3 o2 sensor
and just as a reference the fact that gs300cky's car had 5 o2 sensors is not that wierd toyota has been know to add extra 02 sensors to California original or other high emissions states i had a 89 cressida California car and it had two sensors when it was supposed to have one same goes for supras as well
Code 71...replace the Modulator. Its very common on these cars. Mines just went on and it actually went away after I removed the vacuum line to it and was checking it and the egr valve to see if it was sticking. Im still replacing the Modulator because the code will prolly come back on...the parameters to setr the code are small as hell...like 3rd gear, 5 mins of half throttle, engine warm, etc something like that.
