Aristo - jzs147 - Torque converter
Does anyone know whether the Jzs147 Torque converter is the same as the MkIV Supra TT converter?
I am doing a Aristo swap in my 95 GS and retaining the Auto tranny from the Aristo however, I want to give the car a little bit more torque/getup from the standing position.
From your experience, what are your guys' recommendation?
What is the stock stall speed of the Arsito converter?
Will a MkIV TT Supra one work?
Thanks in advance guys.....
Moe
Moe
alright... no hits.. wow....
Anyways...they are same and will interchange. Just in case someone else had this question.
Found this out courtesy of friends from Supraforums :
If youre still asking, I believe the torque converter is the same in an Aristo / Supra
Stock is 2200RPM
Edit: http://clubaristo.net/forums/showthr...rque+converter
And i see you already found answer
Stock is 2200RPM
Thanks Guys. So if the stock one is 2200 stall, if I get one that is rated As 2800 shouuld be a decent upgrade..or should I go higher.
Epik....are you using upgraded torque converter?
