Radiator for 2jzgte swapped 1g GS300?
As the title states, looking for a compatible radiator for my car which has a swapped Aristo GTE motor in it. Current radiator has a been inlet neck and is leaking under pressure. Will a 93-98 Supra radiator fit (I am certain with fabrication it would, but looking for easiest at the moment). Thanks!
Yea you need a supra radiator, you will have to reposition the brackets on the bottom though. cut and weld in the new spot to fit the supra radiator
