need help please
I recently bought an aristo non turbo motor&auto tranny doing a swap to my 93 gs300 iam running into a oil pan problem the aristo motor has the pan in the middle were the motor mounts up to the car an my car has it on th front can i just change the oil pan from my motor an install it to the aristo motor????????
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Yes you can, but you will need to change the aluminum upper housing of the oil pan as well inlcuding the baffle, the oil pickup and the lower pan.
Looks like the motor you got is not from an Aristo, but rather from a SC300 or a Supra, which are both Rear Sump...and not front sump like the Aristo/GS300.
1siksc
Performance & Maintenance
12
10-29-08 07:19 PM
2jz02
07-23-08 11:25 AM
